i have a set of weld pro stars that are fitted with mickey thompson street radials 275x60 15 they are new never driven on but they are mounted. the bolt pattern is 5x4.5 the wheels sixe is 15x12 with 6.5 back spacing they fit perfectly on a 99-04 with a 79-98 rear end.. just incase you dont know these are 5 lug. the fronts are 15x5 i have the spacers needed to clear the cobra front brakes if that is what you need. the front tires are also new.. these tires hook in dirt! i cut a 1.3 60' at the track and the car hooked the same on the street. there was no modification needed to run these
900.00
here are some pictures
900.00
