Here's my project TURBO_HO (#2). Car started out as a 1993 2.3L my sister purchased new in late 93' After my first turbo car shit rods, I sold it and started on the notch.
Here's the wk into the car so far.
ENGINE-310ci SBF
FRPP A4 Block
Cola Billet Crank (Stock stroke)
Oliver Billet Rods (Stock Length)
Venolia Flat-Top Pistons (+.060)
Speed Pro Moly Rings
Canfield Alum Heads. 62cc/ 225cc
1/2" Head Studs
Cometic MLS Head Gaskets
FRPP F303 Cam
Comp R-Lifters
TFS Chromo P-Rods
Comp Pro Mag Rockers
K-Motion Double Springs
Wysco Fabbed Valve Covers
Hogans Tall Runner EFI Manifold-----:boobs:
Chassis/Suspension
UPR Chromo K-Member
UPR A-Arms
Strange Adj. Struts
UPR Coilovers w/ 150lb Springs
UPR Caster Camber Plates
UPR Bump Steer kit
Flaming River Manual Rack/ SS Shaft
5.0 Spindles/ brakes --- Soon to be Strange Pro Series
Aerospace Manual Master Cylinder
Jegs Line Lock/ Proportioning Valve
Wolfe Upper/Lower Adj. Control Arms
Wolfe Anti-Sway bar
Strange Adj. Shocks--- Going to Aldan Adj. Coilovers *(Autoweld Chassis)
8.8 From a 94 Gt. Moser 31spl, Detroit Locker, 3.73's, Disc brakes
U-Joints built DS---SUPER BURLY
Wolfe Thru-Floor Subframe's - not installed
MISC
Built C6 w/ alto/ kolene/ TCI VB/ Hurst Q-stick
UCC Converter
Innovators West 0oz Balancer
Innovators West Crank Trig/ Bracket
Meizere Series 300 WP/w/ Idler
March Pulleys
Jegs Alt. Bracket
SN95 Alternator
Big Stuff 3 DAI --- :secret:
Precision 82Lb/Hr Injectors
Aeromotive Pro Series EFI Regulator
Product Engineering Single EFI pump
Russel -10 Feed/ Return
Russel -8 Rail feed's
MSD Pro Billet
MSD HVC II
MSD 8.5mm SCD
Jegs 10g Fuel Cell -12 Outlet
Griffon Alum 3 rod Rad
Precision 3" Turbo Headers
Tial 38wg
Tial 50 DV
Precision Super 76 --- PT/Tial 42R *on the way :secret:
4" Turbo Back w/ SW 6" Muff
4" FMIC w/ 3" pipes
Holeshot 5 hole's
MT ET Streets/ Eagle Front Runners
All wk was done @ Wheels Up Racing by Mike and Myself.
Custom Turbo Kits/ Fabrication/ Engine Assy.
Not Bad for my first build!
ENGINE-310ci SBF
FRPP A4 Block
1/2" Head Studs
FRPP F303 Cam
Comp R-Lifters
TFS Chromo P-Rods
Chassis/Suspension
UPR Chromo K-Member
UPR A-Arms
Strange Adj. Struts
UPR Bump Steer kit
Wolfe Anti-Sway bar
MISC
UCC Converter
March Pulleys
Jegs Alt. Bracket
SN95 Alternator
MSD Pro Billet
MSD HVC II
MSD 8.5mm SCD
Tial 38wg
Tial 50 DV
4" FMIC w/ 3" pipes
Holeshot 5 hole's
