What kind of a shifter do you have? If it's a B&M I think some times the ratchet shifters require two clicks to get from reverse to park. Make sure the cable is adjusted right so that it can fully engage into park. That's all I got.
I'm sure he will if he can't figure out the problem, probably nothing to hard and Angelo isn't exactly just across the street.Take it to angelo im sure he will help you out sean
**** yeah,havent seen the car on the streets in a whileNot sure when it'll be on the street, should be tomorrow night...
