So I went to the track last night with the new tranny and restalled converter. The damn trans brake still doesn't want to work when it's under load, after a burnout. Gonna try to put it on a relay and see if that does the trick. So after 2 passes of doing a burnout then trying the brake (and it not working) I said **** it and drove straight to the line without doing a burnout. Got the brake to work, left on about 10-12lbs of boost, spun pretty good and went [email protected] This is on 13lbs, pump gas. I think it has 10.1-10.2 in it with the brake working properly. After I get that sorted out, it'll be time to turn the boost back up.
I am very happy with the new tranny, it shifts FAST.
