21 - 33 of 33 Posts
· 331 Stroker
Discussion Starter · #22 ·
For what it's worth, I wouldn't spray anything with a dual plane on it, If you feel the Vic.JR has too much cross section for your RPM curve, you might rethink the Torquer II, not the greatest manifold out there but with a 1" carb spacer and the plate, it'll have plenty of mid range when you're not on the button...just a thought.
that is what i heard as well. what could i do to get more mid range power from a victor jr. I have a victor jr i can buy right now with ready fogger slots. or if i went with the rpm air gap i could just do fogger set up.
The things you could do to pick up the velocity are only bandaids,a smaller carb, advance timing, fill the plenum, plenum turtle, just get the Vic.JR from Frank, the minor midrange loss's will be nothing compared to the gains when you're on the button, do you know what your heads flow?
· 331 Stroker
Discussion Starter · #25 ·
i beleive the heads flow in the vecinity of 265-270 cfm. what do you mean by filling the plenum and also plenum turtle? and thank you for the advice I will take in all i can get. i am still young and still learning alot.
· Bolt Speedman
a9l is a mass air computer from 89-93 mustangs, the rpm extender is something FMS used to sell to bypass the factory rev limiter and set air fuel.. been discontinued from ford for a while now
At what lift do your heads flow these numbers and do you know what they flow @ .200, the reason i ask is, a "big" manifold coupled with poor low lift flow numbers makes for a pretty lazy street cruiser.
reducing the plenum volumn with epoxy will give more response {with a sacrifice} on the top end, a turtle is an insert that fits the plenum floor, some say they work , others don't.
· 331 Stroker
Discussion Starter · #31 ·
i actually have the flow chart here on a stock pair just like mine. here is the site to check it out....
http://static.trickflow.com/global/images/chartsguides/t/tfs_af_high_port_ss.pdf ...
so what i was thinking is i am going to just buy the rpm air gap. along with that i am just going to drill into the manifold to make room for a fogger set up. that will take a way the worry for the duel plane problem badnews was stating. i am thinking that will give me best of both worlds, low end torque for streetability and even nitrous flow. what do you think?
Personally, I've never had much use for bottom end torque, traction can be hard to come by on the street.
I've never seen a fogged Performer RPM, so I can't say what your in for, even though the distribution is much better with the RPM than a standard Performer, be prepared to do a lot of plug checks until you get a handle on the tune.
ps couldn't open the link, dosen't really matter now anyway.
· 331 Stroker
Discussion Starter · #33 ·
High Port Street/Strip Cylinder Heads for Small Block Ford
Lift Value Intake Flow CFM Exhaust Flow CFM
0.100" 67 55
0.200" 133 103
0.300" 186 138
0.400" 230 166
0.500" 257 183
0.600" 267 193
Tests conducted at 28" of water (pressure).
Bore size: 4.030"; exhaust with 13⁄4" pipe.
21 - 33 of 33 Posts
