1 - 14 of 14 Posts
· 3rd Gear
I have a 1.80 straight cut billet planet powerglide for sale.
Comes with JW ultrabell 164 t SBF
Neil Chance turbo converter
Cheetah shifter
twin coolers with fans and -6 steelbraided line.
Hughes deep pan.
alum trans shield.
All parts are fresh. asking $4000.00
· 5th Gear
I know finchstang needs a power glide. and possibly trans cooler stuff. if he doesnt need trans cooler stuff i do. and i know cisco spooledup needs the bell housing if you decide to seperate.
· E85 veteran
Cheetah shifter
Hughes deep pan.
alum trans shield.
I am not sure if you looking to part it out but I might be interested in a few things. The ultrabell, converter, driveshaft, dip stick, and possibly the coolers. I understand if you want to keep it together but just throwing it out there.
I hope you are planning on going another route and not parting out the car.
· E85 veteran
I saw your post on Corral I think and you said the drive shaft is an inch shorter, I am assuming this is cause you had the engine back on the last hole of the k-member? You also said the flexplate is a zero balance. I would need a 50 oz for my setup right? Are the coolers and lines long enough to go to the back of the car or where they intended to go near the radiator?
· 3rd Gear
Cooler lines are long enough to run under the trunk floor. plumbed in series. You would need a 50oz imbalance for your motor.
And the engine was set back to the 2nd hole in the k-member
I'll sell you the engine too. that way you can run the flexplate . lol
1 - 14 of 14 Posts
