1 - 8 of 8 Posts
You could still get more out of it. Trim off the top half of the cross shaft that holds the blade and shave the screws.
Did you do the bumpstop mod? Can't tell shit with that little pic.
· On the hated list
thanks for the info i will do it. and i did not do the bump stop mod..whats that do
Allows the throttle body to actually open all the way, usually they don't. Mine was only opening 96%. You check the TPS voltage with the Key On/Engine Off and it should be (if I remember right) 4.75V at full throttle. If not, you grind back the bumpstop until that's what it reads. I just ground it way way back and put in the set screw so I could adjust it easier.
I did a writeup for this years ago and it got copied all over the place. Here's the text, but it seems the pix are long gone. I guess I'll have to redo it and get the pix back up.
LS1TECH - View Single Post - Mod Guide: Induction and Exhuast (PLEASE READ BEFORE POSTING)
1 - 8 of 8 Posts
