It'll be fine at those pressures. Don't sweat it.
It is the same pump the car has had since I got it. My fear is that it is dropping because something is starting to get loose. The car used to see about 18psi but that was also during colder months. I guess I'll just continue to hope that it holds together.Joe, according to my engine builder the High Volume pump may have been the reason mine let go.. he made me buy an aftermarket stock pump..
did you change the pump or is it the same pump you had in the car b4 you did the head and headgasket etc.. ? if your seeing less pressure that you were with the same pump something might be getting loose.:twocents:. anywho.. let me know if i can help..
haha love you Will but I think i'll try the 40w before moving all the way to 90w:lol:add some 90w get errr done lol
not sure the thicker oil is the best way to go.. once it's pumped to the top of the motor it takes even longer to get back down to the pump.. :banghead: never ending cycle.. but, 18psi at idle seems really low on a SBF.. i've heard you can get away with low oil pres. on a SBC but i don't like to see less than 25-30 at the stop light.. you might call and ask Chris Groves (Dyno Edge 299-3313) he will have a better answer for you.. wish i could help more..It is the same pump the car has had since I got it. My fear is that it is dropping because something is starting to get loose. The car used to see about 18psi but that was also during colder months. I guess I'll just continue to hope that it holds together.
The only thing that was changed was the headgasket, intake gasket, and put head studs in. Motor didnt let go, just a headgasket.I raced sean in his vett a few years ago and missed a shift and my pressure went down Idle pressure when cold was around 60... 40ish while driving and 12 to 15 at idle but prior to that 35 or so hot at idle come to find out that #2 main spun just enough to block part of the oil hole. not saying that is the problem or not but... what was your oil pressure prior to your rebuild. did you use the same pump and bearings?
There wasn't any water in the oil was there?The only thing that was changed was the headgasket, intake gasket, and put head studs in. Motor didnt let go, just a headgasket.
Did we ever find out if this was going on before the HG went?I am not sure. I was not there when the Oil was drained.
It usually does it right before a oil change.. that is something svo90 just reminded me of..Did we ever find out if this was going on before the HG went?
I don't have a dipstick but the car does always run less oil pressure right before I change the oil.. I'll definitely change the oil and see just how much oil comes out.how much oil do you have in the motor at the moment mine did the same thing come to find out i was burning it and it was 3 qts low if not more
Why don't you have one?I don't have a dipstick
