1 - 20 of 25 Posts
In the slow lane
its about damn time. should be up and running in a few weeks.
here are some pics.
In the slow lane
Uh oh. Remind me of the specs?
414 stroker LS2 block, ported stage 3 LQ9 heads milled to 69cc, forged eagle crank, eagle rods, diamond pistons, healthy cam, 92mm throttle body and intake manifold.
GetSOM!!!
Very tasteful!
Nice Phil
Car should make 500+, or at least it should.
Considering Eddies(01SSCam) 346+MS4 made 490rwhp.
Goodluck, hope to hear some good numbers out of that car.
490? When did this happen?
Phil, your car should be in the mid 500's I think, mine made 491 back when I was on the stock bottom end with H/C/I. That bitch is gonna roll out!
Do you even lift?
480=485=490=500 blah blah
It varies from dyno to dyno, we all know that... he made 485 with a cutout though, never dynod with the duals and bogarts on the rear or the short belt off :pimp:
I would easily say it should be knocking on the door of 500+rwhp on TSP's dyno now, and if not, then it will on a speed density tune.
When you're talking about stock bottom end, heads and cam cars, it does matter. 480-500 is not the same. TSP's dyno and the dyno at Dyno Edge are within 1hp of each other, I have the sheets to verify.
Would, should, if, blah blah blah
1 - 20 of 25 Posts
