1 - 7 of 7 Posts
· E85 veteran
Pro Bullet DSS 306. Its a level 10 block, has forged pistons, I beam rods, main girdle, ARP bolts, and I believe the compression ratio is 9.5 to 1. It also has an F cam in it. I have all the bolts hardware ect, it also has some ARP head bolts. I am including some stock heads with upgraded valve springs. I took the heads off to inspect the pistons and all the cylinders except 4 and 8 are clean. Those two have some detonation marks with #8 being the worst. It comes with everything pictured. It came out of a running and driving car. SOLD
157 tooth JW Ultra bell SBF to powerglide (tranny not included) SOLD
BBK Edlebrock 70mm throttle body SOLD
Extras.....
Tan SN95 front seats SOLD
Power steering rack from 1989 LX Mustang SOLD
Next up is the Cartech street sleeper turbo kit. It includes the upgraded ITS 70mm turbo. I do not have the intercooler piping as I sold it to go with 3 inch so I could use the PMAS 3 inch pro tube. (I was told that using smaller diameter piping with it would cause the car to run bad). You can get an intercooler on ebay for around $200 with 3 inch piping but it will need a little welding. That is what I bought but I am still saving mine. Included is the 70mm ITS turbo, two manifolds, cross over pipe, downpipe, oil lines, and Tial wastegate.
SOLD
42lb injectors I believe they are made by Lucas SOLD
PM or email [email protected] or call 505-718-9525.
Thanks
Cisco
· E85 veteran
Lowered the price on motor to $1300 I want this sold so I can buy some wheels ;).
1 - 7 of 7 Posts
