GM LS ENGINE
The LS series is a new design intended as the only V-8 engine utilized in General Motors' line of RWD cars and trucks. The LS series was a clean sheet design with nothing in common with the classic Chevrolet small block V8. The LS is all-aluminum and has 6-bolt main bearing caps.
The LS engine has been the sole powerplant of the Chevrolet Corvette since 1997 and has seen use in a wide variety of other General Motors vehicles, ranging from sport coupes to full size trucks. Due to the engine's relatively compact external dimensions compared to its displacement and power output, the engine family is also a popular choice for kit cars, hot rods and even light aircraft.
GENERATION III
The Generation III V-8 engines replaced the LT family in 1997. These shared the same bore spacing (4.4") as their cast iron predecessors but almost everything else was changed. The bore was reduced to 3.9 in and the stroke longer at 3.62 in. The engine blocks were cast in aluminum for car applications, and iron for most truck applications (notable exceptions include the Chevrolet TrailBlazer). The engine also introduced coil-on-plug ignition. The traditional five-bolt pentagonal cylinder head pattern was replaced with a square four-bolt design, and the pistons are of the flat-topped variety. The cylinder firing order was changed to 1-8-7-2-6-5-4-3, so that the LS series now corresponds to the firing pattern of other modern V8 engines (for example the Ford Modular V8).
LS1
The LS1 shares little other than similar displacement, external dimensions, and rod bearings, with its predecessor. It is an all-aluminum 5.7 L (5,665 cc/345.7 cu in) pushrod engine and was rated between 305 - 350 hp (227 to 261 kW) and 335-375 ft·lbf (454-508 N·m) of torque in North America, depending on the application. In Australia, continuous modifications were made to the LS1 engine throughout its lifetime, reaching 382 hp (285 kW) in the HSV's YII series and a Callaway modified version, named C4B, was fitted to HSV GTS models producing 402 hp (300 kW).
The version fitted to the 2004 Pontiac GTO was rated at 350 hp (261 kW) and 365 ft·lbf (494 Nm) of torque. Beginning in 2001, the LS1 received the higher-flowing intake from the LS6 and a milder camshaft to keep power at the same level; this also allowed GM to remove the exhaust gas recirculation (EGR) system (Camaro/Firebird only; 97-00 Corvette LS1 never used an EGR system). The block is very similar to that of the higher-output LS6; beginning in 2002, some LS1 engines were actually built using the LS6 block instead. The LS1 was on the Ward's 10 Best Engines list for 1998.
Applications.
1997-2004 Chevrolet Corvette C5, excluding Z06
1998-2002 Chevrolet Camaro Z28, SS
1998-2002 Pontiac Firebird Formula, Trans Am, Trans Am WS6
2004 Pontiac GTO
1999-2005 Holden Commodore Ute
1999-2005 Holden Commodore (VT, VX, VY, VZ)
1999-2005 Holden Statesman (WH, WK, WL)
1999-2005 Holden Caprice (WH, WK, WL)
1999-2004 Holden Special Vehicles (all V8 models)
2001-2005 Holden Monaro CV8
2006-2007 Elfin MS8 Streamliner
LS6
LS6 can also refer to a 454 in³ Chevrolet Big-Block engine of the 1970s.
The LS6 is a higher-output version of GM's LS1 engine and retains the same capacity. The initial 2001 LS6 produced 385 hp (287 kW) and 385 ft·lbf (522 N·m), but the engine was modified for 2002 through 2004 to produce 405 hp (302 kW) and 400 ft·lbf (542 N·m) of torque. The LS6 was originally only used in the high-performance C5 Corvette Z06 model, with the Cadillac CTS V-Series getting the 400 hp engine later. The V-Series used the LS6 for two years before being replaced by the LS2 in 2006. For 2006, the Z06 replaced the LS6 with the new 7.0L LS7.
The LS6 shares its basic block architecture with the GM LS1 engine, but other changes were made to the design such as windows cast into the block between cylinders, improved main web strength and bay to bay breathing, an intake manifold and MAF-sensor with higher flow, a camshaft with higher lift and more duration, a higher compression ratio and a revised oiling system better suited to high lateral acceleration.The casting number, located on the top rear edge of the block, is 12561168.
Applications
2001-2004 Chevrolet Corvette C5 Z06
2004-2005 Cadillac CTS V-Series
Generation IV
In 2004, the Generation III was superseded by the Generation IV. This category of engines has provisions for high-displacement ranges up to 7.0 L and power output to 638 hp (476 kW). Building upon the Generation III design, Generation IV was designed with displacement on demand in mind, a technology that allows 4 cylinders in alternating fashion from side to side and front to back to be deactivated. It can also accommodate variable valve timing. A 3-valve per cylinder design was originally slated for the LS7, which would have been a first for a GM pushrod engine; but the idea was shelved owing to design complexities and when the same two-valve configuration as the other Generation III and IV engines proved to be sufficient to meet the goals for the LS7. It has been reported that the LS3 and an upcoming 6.0L Vortec engine represent the final two designs to be considered in the Generation IV engine family, and that future designs - expected around 2009 - will be part of the Generation V engine family.
L76
L76 was originally Holden's version of the 6.0 L (5,967 cc/364.1 cu in) Generation IV engine. While displacement on demand technology was disabled on Holdens, this feature is enabled on the 2008 Pontiac G8. The engine also meets Euro III emissions requirements. Output is 348 hp (260 kW) at 5600 rpm and 376 ft·lbf (510 N·m) at 4400 rpm for the Holden variant, and 361 hp (269.8 kW) and 385 ft·lbf of torque (526.5 N·m) for the G8 GT.
Applications:
2006 Holden VZ Commodore
2008 Pontiac G8
L98
The L98 is a slightly modified version of the L76. Since Holden does not use displacement on demand, some redundant hardware was removed from the L76. Power increased to 362 hp (270 kW) at 5700 rpm and 391 ft·lbf (530 Nm) at 4400 rpm.
Applications:
2006-2007 Holden VE Commodore
2006-2007 Holden WM Statesman / Holden WM Caprice
2007-2008 Chevrolet Lumina SS
2007-2008 Chevrolet Caprice SS
L99
The L99 is derived from the LS3 with reduced output but adds Active Fuel Management (displacement on demand), which allows it to run on only four cylinders during light load conditions. Power is 400 hp (298 kW) and 395 ft·lbf (536 N·m) of torque.
Applications:
2010 Chevrolet Camaro
LS2
The LS2 was introduced as the Corvette's new base engine for the 2005 model year. It produces 400 hp (298 kW) at 6000 rpm and 400 ft·lbf (542 N·m) at 4400 rpm from a slightly larger displacement of 6.0 L (5,967 cc/364.1 cu in). It is similar to the high-performance LS6, but with an improved power peak and more torque throughout the rpm range. The LS2's in the E-series HSV's are modified in Australia to produce 412 hp (307 kW) and 412 ft·lbf (559 N·m).
Applications:
2006-2007 Cadillac CTS-V
2005-2007 Chevrolet Corvette
2005-2006 Chevrolet SSR
2006-2008 Chevrolet TrailBlazer SS
2004-2007 Holden Special Vehicles (all V8 models)
2005-2006 Pontiac GTO
2008-2010? Saab 9-7X Aero
2005-2006 Vauxhall Monaro VXR
LS3
LS3 can also refer to a 402 in³ Chevrolet Big-Block engine of the 1970s.
The LS3 was introduced as the Corvette's new base engine for the 2008 model year. It produces 430 hp (320 kW) at 5900 rpm and 424 ft·lbf (575 N·m) at 4600 rpm without the optional Corvette exhaust and is SAE certified. The block is an updated version of the LS2 casting featuring a larger bore of 4.06 in (103 mm) creating a displacement of 6.2 L (6,162 cc/376.0 cu in). It also features higher flowing cylinder heads sourced from the L92, a more aggressive camshaft with 0.551" lift, a revised valvetrain with 6 mm (0.24 in) offset intake rocker arms, a high-flow intake manifold and 47 lb/hr fuel injectors from the LS7 engine.
The L76/L92/LS3 cylinder heads use 2.165 in (55.0 mm) intake valves, and 1.59 in (40 mm) exhaust valves. For use with 4 in (100 mm) and larger bores, they allow for over 600 hp (450 kW) naturally aspirated. Improved manufacturing efficiency makes these heads cheaper than the outgoing LS6 heads, and severely undercuts aftermarket heads. The large valves, however, limit maximum rpm - 6000 in the L76 (with AFM), and 6600 in the LS3 (with hollow stem valves).
In addition to the above, a dual mode exhaust package with a bypass on acceleration is available. The dual-mode exhaust uses vacuum-actuated outlet valves, which control engine noise during low-load operation, but open for maximum performance during high-load operation. The system is similar to the C6 Z06, but uses a 2.5 in (64 mm) diameter exhaust compared to the Z06's 3 in (76 mm). Power is boosted to 436 hp (325 kW) and 428 ft·lbf (580 N·m) with this option.
From April 2008, Australian performance car manufacturer, HSV, adopted the LS3 as its standard V8 throughout the range, replacing the LS2. The LS3 received modifications for its application to HSV's models, producing 425 hp (317 kW). Power and torque was restricted to protect the drivetrain currently used in the E-Series sedans.
Applications:
April 2008-present Holden Special Vehicles (all V8 models)
2008-present Chevrolet Corvette
2009 Pontiac G8 GXP (source: Pontiac web site, "Upcoming Vehicles," 3-16-2008)
June 2008-present Vauxhall VXR8
GENERATION III
LS1
Applications.
2004 Pontiac GTO
LS6
Applications
Generation IV
L76
Applications:
2008 Pontiac G8
L98
Applications:
L99
Applications:
LS2
Applications:
LS3
Applications:
