FS:SBF,Glide, blow thru stuff & mustang parts
946 Views 10 Replies 5 Participants Last post by  slocoupe88
FRESH Dart Iron Eagle based 363 shortblock 4.125 bore 3.40 stroke, Eagle zero balance crank, eagle H beam rods.
gas ported CP flattop pistons, low tension rings. 3 spare pistons Moroso pan, comp cam HR 576lift 240 int 242 exh duration @114 deg lobe sep. CSR water pump, march alt bracket and idler,
SOLD
TFS R heads . solid roller set up W/ probe stud girdle and 7/16 pro magnum rockers,7/16 arp studs, SS valves,sheetmetal valve covers.
will include springs for Hyd Roller set up.
$2000.00
Powerglide W/ transbrake, stock case and modified pump . BTE 1.80 billit straight cut planets, JW ultra bell. Neil Chance turbo spline converter. 3400 stall set up for turbocharger. 1350 drive shaft with spicer yoke and u-joints 3-1/2 dia tube built for 1" engine setback. Cheetah SCS Shifter.
Trans shield over case,Hughes deep pan,Dual coolers with fans and -6 an lines.
$3500.00
NEW CSU carbs, 750cfm blow thru carb built for E85.
McClintic dual needle and seat bowls
$1000.00
NEW product engineering PE460 fuel pump. rated at 2000hp at 36psi
$450.00
Aeromotive 13202 regulator. boost referencing. for blow thru set up
$200.00
NEW Wolfe racecraft double adjustable upper control arms, Single adjustable
lower arms. Sperical bushings
$SOLD
NEW Aerospace front brakes. 4 lug 4 piston caliper with modifies stock spindles
$SOLD
NEW Strange 10 way adjustable shocks and struts for mustang fox
installed on car but never used
$SOLD
All items are OBO
Call Text or PM with any questions
Shane 505-307-1973
1 - 11 of 11 Posts
Damn if those brakes were 5 lug id be all over em.
Aerospace will sell you 5 lug hubs seperate, or you can have these re drilled.
too much work/to expensive. Rather just get the right ones. Thanks though.
TREY
Just curious are you real firm on the price for the brakes? I've kinda been looking around for a set but not ready to spend quite that much.
Yeah pretty happy with the price right now. If i dont have any luck in a couple weeks I'll let you know
Thanks ,Shane
are the rear shocks for the stock mount location?
Yes
Are you willing to ship? If so give me a price for 70743 zip code
I'm gonna part the transmission out if anyone is interested.
JW Bell hsg 164t 200.00
cheetah SCS shifter $250.00
Neil Chance turbo converter $900.00
1.80 billit planetPowerglide w/ hughes pan and trans shield $1500.00
1350 spicer driveshaft $250.00
trans coolers w/fans and -6 ss lines $225.00
All pieces are obo
1 - 11 of 11 Posts
