FS: Miscellaneous Mustang Stuff
646 Views 7 Replies 3 Participants Last post by  El Jefe
Can provide pix of anything you wanna see.
--12" length, 165lb springs for front coilovers. Bought from MMR. $50
--Aeromotive fuel regulator, fits stock Fox rails. PN#13103, 30-70psi, 1:1, red. $120 new, I'm asking $75.
--Two 335/35-17 Hoosier drag radials. These have approx. 250mi on them, 3 passes at the track. I would suggest minimum 10.5" wheels. $300 OBO
--UPR solid engine mounts for 302. Put them in last year and only have about 500 miles on them. UPR Part Number: 3013-01 $50
--Electric fan, S-blade. Not sure on brand. Similar fans flow somewhere around 1500cfm. Easily enough for a bolt-on Fox, I think it came off a blower car. - $40
--Aluminum fuel rails for Mustang 5-liter with Victor style intake with vertical-mount injectors. Will not work on factory style intake (Trick Flow, Holly, GT40/Cobra, etc.) Includes A/N fittings on rails. - $50
--Comp Engineering rear coilover mounting kit, universal. Has both the rearend brackets and the shock mounting brackets for the rearend housing, and all hardware. Never used. - $50
--Manual brake conversion plate, does away with the stock brake booster. I believe it's a Skinny Kid piece. SOLD
--1994 Cobra OEM wheels and tires. 17x8 wheels mounted with 255 Goodyear Eagle GS-Cs, tires have about 40-50% tread left. Wheels have normal nicks and road wear, nothing major. Does not include lugnuts. - $300 <--Lowest I will go
[email protected] or text/call 575.308.9808.
Will split shipping on small stuff or can meet halfway to Albuquerque for wheels (I'm in Roswell). Email me if you're anywhere else to set something up, no PMs please.
1 - 8 of 8 Posts
TTT
TTT Lowered prices some more.
--Manual brake conversion plate, does away with the stock brake booster. I believe it's a Skinny Kid piece. $25
I'll take this, paypal or are you going to be up here anytime soon??
I dont use paypal, prefer check or money order. I don't plan on being there soon, but shipping it to you would only be about 5 bucks which ain't no problem.
Cool, whats your address, I'll send a check.
TTT
I am going to Artesia tomorrow dropping off a load, going right through Roswell. If someone wanted something from Buffhomer, I could pick up for them.
Not much time to get it organized since I am heading out at 7am tomorrow, but thought I would throw this out there.
1 - 8 of 8 Posts
