1 - 5 of 5 Posts
· Banned
Laurier large flat panel TV stand, oak veneer with LED lighting!! - $325
60" Laurier TV stand: This modern oak-finish TV stand is 23" high and 62" wide. It's wide enough to hold flat panel or rear-projection TVs up to 60", as well as most large standard TVs. Interior lighting: LED interior lighting add elegance while making it easier to view your stored media items in a darkened room. Sliding glass doors: Sliding glass doors enclose the outermost shelves. The unit itself is constructed with three two-shelf columns. Ventilated for A/V components: This TV shelf is ventilated so that your A/V equipment will not overheat during use. You don't have to worry about putting anything together, because this stand comes fully assembled. Dimensions: 21" H x 62" W x 21.3" L
There is nothing wrong with it at all, lightly rubbed on the right side from the cardboard in shipping. Nothing noticeable from ~2' away.
at my old place
Z-Line Component stand with glass - $30
Z-Line Component stand, with three glass shelfs. Purchased from Circuit City many years ago, only to sit in the garage because I have no use for it. All the glass is pictured securely on the top of the stand. No issues, very stable.
(on right)
Dell 20" LCD widescreen computer monitor - $75
Dell E207WFP computer monitor, with both VGA and DVI connections.
Comes with power cable, stand, and DVI video cable. 100% working order.
Only issue is I thought it broke because it would not power on, it was only the plastic power button that broke and was not depressing the button behind it. I removed it so now it will power up correctly. Picture is below of missing plastic button. Super high resolution and great contrast ratio!
* Resolution: 1,680x1,050
* Dot pitch: .258 mm
* Pixel-response rate: 5ms
* Contrast ratio: 800:1
* Viewing angle: 160 degrees horizontal, 160 degrees vertical
* Connectivity: DVI, VGA
* HDCP compliant, can work with a DVI to HDMI cable if needed
* Included DVI cable
I also have a Gateway 17" LCD monitor that I will let go for $50. It works great, no issues at all. Model # FPD1730. Comes with power cable, stand, and VGA cable.
Also I have the front brakes off a K7 2007 GSX-R1000, everything but calipers and rotors.
Master cylinder, pads, and lines. All for $70obo. Cosmetic rash on MC but does not effect operation.
Contact: Diego @ 505.917.4705
Email @ [email protected]
· What's Next?
That Dell monitor is bad ass. I love Dell's, I run two 24" and two 20" dell monitors, and absolutely love them. Good luck with the sale.
(BTW, that is a hell of a price. Probably half price of what you can get them on ebay for)
· Banned
Thanks for the bump! I am moving and trying to get rid of stuff so I dont have to pay for storage! Make me an offer, I would like to move it all this weekend!
PS The stand was MSRP $700!! And its practically brand new.
1 - 5 of 5 Posts
