*NOT FOR SALE* 1988 Mustang coupe 331 stroker w/67mm turbo
Changed my mind, lol Listing this for sale, need to make some room in the shop plus I am dumping some heavy money into projects sitting around this car. Car runs great, runs on pump gas, could be daily if you wanted it to be, very nice and very straight, this is the cleanest coupe I have ever seen. $17,500
Body and paint
10 out 10 $7k in paint and body and its perfect show quality
All jambs painted. doors ,trunk, etc,
All trim body and window are new
Door and trunk seals are new
Interior
7 out 10 “Grey”
Engine
Ford Strokers.com ” DART BLOCK” 331 STROKER
Scat crank
H beam rods
Diamond dished pistons
AFR 185 heads
Cometic head gaskets
Edelbrock high volume waterpump
Aluminum radiator 2 core
Arp head bolts
Comp pro magnum 1.6 rockers
Anderson cam
Edelbrock rpm intake
Accufab 70mm throttle body
Moroso 7 qt oil pan
Power adder
Ponydown Stage 2 turbo kit “intercooled”
Turbonetics t-76 turbo
Tial wastegate
Hallman boost controller
Drivetrain
Astro A5 transmission 5 speed
Ram HD clutch
Ram Billet flywheel
Ford racing Aluminum drive shaft
Steeda adjustable clutch cable and quadrant
MGW short throw shifter
Moser 31 spline axles 5lug
Ford Racing Cobra 31 spline traction loc carrier
Arp wheel studs
Pro motion aluminum diff cover
Fuel
Aeromotive 340 Stealth pump
Aeromotive FPR “boost reference”
-8 feed fuel lines
-6 return fuel lines
60lb siemens deka injectors
Billet fuel rails
PRO M maf Calibrated for 60’s
Exhaust
Dynomax ultrafows
2.5” stainless steel tips
Suspension
Maximum motorsports caster camber kit
Sn 95 5lug front spindle conversion
Eibach springs
Granetelli adjustable uppers “rear”
Granetelli adjustable lowers “rear”
Wheels
FR500
18x9
18x10
Pics:
Body and paint
Interior
7 out 10 “Grey”
Engine
Scat crank
H beam rods
AFR 185 heads
Arp head bolts
Anderson cam
Moroso 7 qt oil pan
Power adder
Tial wastegate
Drivetrain
Ram HD clutch
Ram Billet flywheel
Arp wheel studs
Fuel
-8 feed fuel lines
Billet fuel rails
Exhaust
Dynomax ultrafows
Suspension
Eibach springs
Wheels
FR500
18x9
18x10
Pics:
