1 - 2 of 2 Posts
· E85 veteran
I am going to change up the Mustang build a little plus right now I am in need of some cash so I am looking at selling some stuff. I am looking to sell everything together but if I cant sell it I might split it up, but I need to sell the big stuff first. Here is what I got.
Pro Bullet DSS 306. Its a level 10 block, has forged pistons, I beam rods, main girdle, ARP bolts, and I believe the compression ratio is 9.5 to 1. It has stock heads on it.
Next up is the Cartech street sleeper turbo kit. It includes the upgraded ITS 70mm turbo. I do not have the intercooler piping as I sold it to go with 3 inch so I could use the PMAS 3 inch pro tube. (I was told that using smaller diameter piping with it would cause the car to run bad). You can get an intercooler on ebay for around $200 with 3 inch piping but it will need a little welding. That is what I bought but I am still saving mine.
I am also including a MSD distributor, MSD ignition box, MSD coil, MSD wires, 42# injectors, PMAS 3 inch pro tube maf, Edlebrock 70mm throttle body, SN95 alternator, Aeromotive fuel pressure regulator, Trick Flow Street Heat intake manifold with modified throttle cable bracket to eliminate EGR, and Trick Flow valve covers.
I am looking to get $4200 for everything. Like I said I might split up some stuff if I can get the turbo kit or motor sold first. You can pm me or email [email protected]
Thanks
Cisco
1 - 2 of 2 Posts
