Looking good! Let me know if you need a hand with the tranny.
No 2 step, just the transbrake.You gonna run a 2step with the trans brake?
The car doesn't need one nor should it ever. I'm doing it for the weight savings. 30lbs lost for 130 bucks, sounds worth it to me. Considering a kmember for these cars cost $500 for a 25lb weight savings, its a no brainer.I never thought those cars needed a mini-tub? You must be looking to make some BIG power in the future.. or atleast get that bitch to hook really well on the street
$130 bucks?? So you will be doing the cutting and welding yourself? That sounds too cheap for an installed price...The car doesn't need one nor should it ever. I'm doing it for the weight savings. 30lbs lost for 130 bucks, sounds worth it to me. Considering a kmember for these cars cost $500 for a 25lb weight savings, its a no brainer.
I can do it myself, but I'm going to let them do it at wolfe when the cage is being done. Its not a very difficult install.$130 bucks?? So you will be doing the cutting and welding yourself? That sounds too cheap for an installed price...
I'm moving the car to the new garage after I get a wheel alignment, you can use this garage anytime man, you know that.Damn Eddie, looks good, maybe when your done using your garage, I can park mine in there so I have a place to work :lol:
Yeah, Rossler Terminator 2 with a couple of changes.Did you already order the TH400?
Yeah, Everything associated with the manual transmission, the driveshaft, and the torque arm.did you get rid of your old torque arm???
