1 - 8 of 8 Posts
Well I got the news on Friday that my work is closing its doors at the end of the month. I have something in the works but I think I need to try and sell the car now rather then have to take it in the shorts later if things don't pan out.
1965 Galaxie 500 Gasser
Bored, balanced, with extensive head work 352 cid with 10.5 to1 flat top pistons.
mild hydraulic flat tappet Sealed Power cam.
Edelbrock Performer RPM intake manifold # 7105.
Edelbrock 750 cfm carburetor.
Edelbrock RPM 250 hp nitrous oxide system, is set up for 100 hp.
2 electric fuel pumps, one on nitrous system & one for backup to
mechanical fuel pump.
MSD 7AL ignition system:
Pro- Billet Distributor # 8594
Timing computer # 8980
8.8 spark plug wires
custom built coated headers by FPA (Ford Powertrain Application) of Puyallup, Wa. 98371
Electrical master shut off switch.
Sun Tach
built C6 by ATaT Transmissions with manual valve body, T.C.I. 3600 rpm stall converter, B & M Slapstick Star shifter, also has external oil cooler.
9” Ford rear:Summit 4:56 ratio ring & pinion gears with mini spool.
Subframed with 64 Ford PU front axle that is drilled and chromed also chromed brake backing plates.
New front leaf springs and bushings.
Front wheel line lock brake for drag racing.
custom built aluminum radiator
Fiberglass Thunderbolt hood from Dearborn Classics, has not yet been painted.
New right rear quarter panel from Obsolete & Classic Auto Parts
The car is in great shape to cruise in but could use a paint job.
Rear tires: Mickey Thompson ET Street 28 x 11.50 x 15LT.
New dash pad.
All glass in nice shape and windows in good working order.
Interior is OK
It's ran a 13.6 on the bottle (its a dog on the motor)
$7500.00
720-2001 Shane:banghead:I know I will regret this
· Psssh. Mustang
Sad times :( but it happens.
I hope you get every penny you ask for.
I'm a loan officer. I've been doing residential home loans for the last 10 years. I owned my own shop from 2003 to June of last year. I tried to hold off and not lay off any of my employees from mid 07 until I closed in June 08 and went without any pay during that time. Since then I've had the reverse midas touch, every place that I've went to either ran into warehouse line (funding) problems or folded completely. I'm at a mortgage banker now and things look great, but its commission only and I won't get my first checks until mid Dec. It's just the nature of the biz. I don't really think I'm qualified to do much more than this and I keep telling myself that people gotta have a place to live, so it HAS to work out. This line of work has received a bad name recently (sometimes deservedly so) but there are quite a few talented, ethical people in it who really care about their clients. I'm just keeping my head up and thinking that we are pretty close to the bottom and things will turn around soon. ;)
New bump for a blown head gasket on my Volvo, yeay. Who's got a daily of similar value to trade? Or lower plus cash is cool too.
1 - 8 of 8 Posts
